  2. UPDATE Can anyone tell me if this photo shows that the engine management light bulb is actually missing? If so can this be replaced or do I need a whole new unit? Thanks
  4. Hi. Just reg’d on here. My aunt just bought from a dealer, a 2013 ‘30th Ed’ 1.2 Micra - manual drive (which I’ve just discovered from online world is a K13, though the paperwork doesn’t state this. I drive this myself. When viewing, I asked the dealer what the thin plastic tape wrapped around a rubber pipe (possibly a manifold pipe? - sits just behind the rad’ fan and attaches somewhere under the battery plate…?) is about. He felt it and stated there’s a crack/split in the pipe and that they’d have it replaced. Before collection, by phone, the dealer advised that it wasn’t a split pipe and so doesn’t need replacing. Typhoon, I forgot what his colleague told us about it when we got there, though the gist of it was that it’s normal/standard. What they had done is replaced the thin ad-hoc looking tape with black plastic (insulation ?) tape. Any thoughts on this (tricky w/o a photo I know; can attach one tomorrow). Any K13 owners/drivers out there who recognise this? Thanks in advance.
  5. Cant find a replacement for it and no windscreen wipers mean can't drive it!
  6. Update: This it was raining today. I realized I never reconnected the drainage tube in the bottom/side of the luggage compartment so I went outside to check. What I found was: 1) The bottom of the tube (blue arrow), disconnected from the valve that goes through the metal wall of the car and into the wheel well, was not wet and there was no water pooling in the bottom of the car. This tells me the water wasn’t reaching the end of the line so it must be kinked or plugged upstream. But remember, I successfully ran a nylon string trimmer cable through the entire tube and found no evidence of dirt clogging the tube. 2) the headliner was the wettest right around the hinge for the cargo access door (red arrow). I could see a drip falling from the metal directly above it, as well as a drip running from the same piece of metal to the left, behind the upper cargo side panel trim. If the leak were coming from the moon roof drain, I don’t understand why it would be so wet all the way back where it is. Are there any other areas where water could enter on top of the car around the cargo door? The antenna for instance? It can’t be the door seal itself because the drip is above the door seal. A leak in the back of the roof still wouldn’t explain the dry end of the tube tube in the lower side panel/floor trim…
  7. Does anyone know why, when I disconnect and reconnect the battery my hardtop opens and closes perfectly, but, when I come to open it next day it won't open until I disconnect and reconnect the battery again
  8. Hi Mike, I have for sale a 2006 uk 350z with 20300 miles, and only 1 previous owner. Totaly standard car in genuinely pristine condition
  9. I think I would just fit a new tyre and then make the comparison from there on
  10. Thanks for giving us feedback on your Juke - its always worth hearing the bad as well as the good points to give a fair assessment of a vehicle. The Jukes have always been a high revving engine due to the transmission gearing but they are better being run at higher revs most of the time to keep the engine from carbon/sooting up, etc
  11. Sounds like water ingress into the electronics or sensors (not sure how deep the water was). If it is allowed to dry out in the sun then possibly it may work then.
  12. Hi again. I took the car for a retest today after having changed spark plugs and oil and adding additive. Emissions are now fine, however, it brought up a previous fault code P03033 which was still on the system although the engine check light was not lit. It turns out that the engine check light never comes on. The centre will not pass the car until I get this sorted. Any advice please?
  13. I have a Micra Sport C+C Auto. The drivers side quarter light window has dropped into the car body. My garage says I need parts they cannot access. Can anyone help me please? Regulator 83720BC000 Motor 83730BC000 Thank you. If no one can help me then I could well be offering this as a parts bank!!! Regards Jan in Sudbury
  14. I have a Micra Sport C+C Auto. The drivers side quarter light window has dropped into the car body. My garage says I need parts they cannot access. Can anyone help me please? Regulator 83720BC000 Motor 83730BC000 Thank you. If no one can help me then I could well be offering this as a parts bank!!! Regards Jan in Sudbury
  15. Earlier
  16. Hi can I need a new radiator for a Nissan Sereena Highway star 1990cc Whare can I get the correct part? Thanks
  17. This is more than likely from the front underside but worth looking underneath at both ends to ensure that your undershield is present at the front/rear
  18. possibly the DPF trying to regenerate but something is stopping the process - check all necessary conditions with the process (e.g. fuel tank of fuel, higher RPM for set period, etc)
  19. I tend to enter details into EuroCarParts or eBay sites to see if they are listing belt or chain for each engine type If in doubt about belt replacement history then changing it is the best way forward
  20. Good luck in your search and may be worth considering countries like Malta, Cyprus and maybe Portugal for any that were sold out there in RHD and they would be in rust free condition and no tax to pay as they are old vehicles
  21. I have always managed to find replacement resistor packs for most cars on eBay More than likely would be the same for most Nissan models - remove it and compare to images of them on eBay
  22. I would ask your local Nissan dealer as to cost and availability of the parts and go from there If its a reasonable price for parts and fitting then would be worth fixing it
  23. Hi.....welcome to the club Good to have you onboard!
  24. I have been told by my nissan dealership the CVT unit is not servicable by them. Nissan GB seem to sy different, fluid change at 90k, and level checked on intermediate services. my 2018 Juke CVT unit is terminal, over 6k to fix!
  25. del
    Quote
  26. Hi people drove car today and going at high revs and car shudder and lost a little power but picked back up again but red engine light came on, it as done it before and the glow plugs needed changing so done them but been good up till now stoped car light went off as I started t back up but as not come back on put on reader it says glow plug in line system any ideas thanks
  27. Is there any way to permanently disconnect the warning chimes when driving above the sign speed limit, in my Qashqai acenta tech?
  28. Hi all i have a 2008 acenta, just had a new starter motor in it and now it as a squeezing which sounds like it is coming from around the alternator area it dose not make the noise when starting up it makes it as I drive but only in 1,2,3,4 gear as I speed up and go into 5,6 gear the squeezing seems to go, I did think it was the brake pads on front drivers side in which case I know need changing but as the sound as gone on for a few day it seems to be more around the alternator belt area Hi ll
