Is this from my car ?
I would imagine if the front hubs are manually unlocked then it should be fine but if auto locked hubs then potentially the different rolling diameter would affect the transfer box, etc....so probably worth ensuring all four tyres are same tread depth as near as possible
Hi I'm looking to get a driveaway awning for my Nissan sereena highway star Does anyone know what make would fit it ? Thanks Cath
Thank you I will pass that on
