  2. I'm having trouble finding the front turn signal (original two-phase) on the left side of the Nissan Pathfinder 2002, does anyone know where to buy one?
  5. I'll be driving in rain on the Interstate and all of a sudden, the cruise control shuts down and the vehicle dramatically slows down. Dash says "Frontal collision" isn't working? WTH causes this?
  6. I had the 1 litre engine in my last Juke. Its turbocharged so there is no loss of power. I now have a 1.6 Hybrid which is more cost effective especially around urban areas.
  7. Hello all, meet Jimi. 1.2 Tekna, just past 37000 miles, owned for 2 weeks. My first Juke, loving it.
  8. I have a 2019 xtrail t32 2019 tekna and looking to put in a viofo dashcam with parking mod and hardwire it in does any one what fuse to plug in for permanent power when car is park and fuse when car is running
  9. I've been re-bushing the suspension on my Sunny Coupe and dicovered how rusty the brake splash shields are but I cannot find replacments. Do you know of someone who might have them?
  10. I would say it is more likely to be a gummed up turbo vanes fault which can be rectified by cleaning the turbo with a specialist cleaning solution (link below) https://www.ebay.co.uk/itm/292493130747?_skw=turbo+cleaner&itmmeta=01JTSXMZ9VE9ZW9F2H1DCM6423&hash=item4419f2fbfb%3Ag%3Ab9sAAOSwYutasp0A&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fpV%2F8bmO6dppPkpUyUyyrTVatA%2BtxVHfyIQW%2BFrQfBfOZwB9GXDgirF%2FZx1wYQ5QWHnndTFW8dxHQnQwE2DJPM593%2FytgJBS5MLBDp8GWH%2FZutClKfIZWQSfoKddANZ7zaeBnZAo6VVmNaP6AcQjlZrAqIw0vsohppQpa1TRGcxd4sUcRwemDzU%2FgJBiFCwMC0j2OXXqnhoSWOhG9lxLcC0VLM4FFWpJ0NKLa%2FFsrMcFmbgwWZs209wAa7IvVnY8g%3D|tkp%3ABlBMUIL1073WZQ&keyword=turbo+cleaner&sacat=0&relatedSearch=true Once you have cleaned it and the vanes are free to move then a good italian tune-up should blast out any residue and carbon and should then run smoothly
  11. Earlier
  12. I would say that is an air conditioning system sensor - possibly system pressure sensor?
  13. okay, best bet really.....let us know how you get on with it
  14. Hi .... and welcome to the Club Great to have you onboard and feel free to post and answer any questions you feel able to answer. The Juke is a great car, my wife has one and just keeps going with minimal repairs (if any) but always maintained to keep it reliable.
  15. Here's a problem to bake your noodle. 1995 k11 Micra, not been driven for a month, 4 new problems have appeared, all lights. 1) left headlight not working. 2) left indicator telltale light not working, either in telltale or hazard mode, external lights all working and relay clicking. 3) handbrake warning light not working. 4) reversing light not working. I'm going to do all the usual checks, starting with the external bulbs, but these systems can't have anything in common, can they?
  16. What colour? there is a set of black seats on eBay at the min. item number is 316640688205
  17. It would seem, and I would wholeheartedly agree. Although, technically, you could leave all previous weights on a wheel for forever, and just keep balancing it with additional weights as necessary!??? 😂 Not the case here though. All the weights are fresh new. They put both push on weights and stick on weights. Push on weights went to the inside of each wheel. Stick on weights are to the outside behind the spokes on the aluminum mag wheels. And.. as stated.. opposite each other in three of the four, and about 2 hours on the clock location off opposite on the fourth. It’s very weird. I have personally balanced a lot of motorcycle wheels in my life.. and it’s always one weight.
  18. Thanks mate will do. Need to find a few bits and bobs but the car is mechanically sound.
  19. Thanks again. I’ve put in new batteries and tried the other fob for a while before. It is so random I am wondering if the door keyless buttons send a signal like the fob or they are hardwired. I’m thinking possibly the rf receiver is getting old and cranky like the rest of us….
  20. Hi....welcome to the Club
  21. Hi....welcome to the forum Good to have you onboard
  22. I am looking for an idea of what the cost of replacing both front and back brake pads and discs for Nissan Qashqai 2019 model ? Thanks
  23. Hi. (This site isn’t allowing me to select the Micra Forum). Just acquired (legally) a 2013 K13 Micra, which came without parking sensors. Online options are so numerous, what a minefield! Any advice out there? Anything gratefully received.
  24. Hi, I am in the process of replacing the timing chain and sprockets on my 2015 Pulsar (70k miles). I'm now at the point of taking the sprockets off the camshafts but not sure how I do this. Is is just the bolt in the centre of each sprocket that needs undoing? Standard thread for both? I also now need a workshop manual to find all the torque settings as part of the rebuild. Can anyone provide a link or suggest a good manual to buy? Of course, if anyone has a list of the torque settings they could share, that would be perfect! Finally - any ideas what may have caused the chain and sprockets to wear at this low mileage? The chain had stretched and was noisy. On removal I've noticed the tensioner was ok but the chain was clearly stretched and all sprockets are well worn - particularly on the crankshaft. I have only owned the car for the last 2 years and the car had been regularly serviced prior to that. Sorry for all the questions on my first post but I appreciate all responses. Thanks
  25. Hi all, I have a 2013 D40 Tekna with a factory-fitted reversing camera which is sited under the handle to open the boot/cargo area. The handle has broken and I cannot find a replacement anywhere. All the ones I can find are standard, without a cutout for the camera, which won't fit - I have attached pictures to show the cutout. Has anyone ever had to replace their handle, and been able to find a suitable replacement?
  26. Hello all, I am new to here and hope you can help, my qashqai has developed this issue when starting in the morning, it struggles to start with a funny turning over sound and eventually when it starts there is alot of white smoke and it idles rough but once it is warm it runs perfectly but with still a bit of smoke, I have been looking around the net, I have seen leaking or faulty injector a clogged up PCV valve I did have the Egr valve changed last year that’s all good. It dose feel like it has loss of power but the turn dose feel like it kick still. When it’s warm it sound spot on, by the way it has done 117k,
