  1. Last week
  2. Hello. I need to remove the original rear vision mirror mount from my nissan pulsar c12 2013 model as the mirror has broken off the mount and I need to replace it with a universal replacement and a glue strip. The mount is glued on and not clipped like the modern mirrors. I have tried breaking the seal gently with a screwdriver and blade but it has damaged the glass on the underside of windscreen. The cracks have not reached the upper surface. I have now tried using string to cut into the seal but i cannot cut right through the seal and it is shearing on glass fragments. I'm wary of using the hairdryer to soften the glue as it may cause more cracks. Any suggestions please? I had thought of using solvent but not sure which is best for this older adhesive. My options are: Fishing line/piano wire to saw through the seal Solvent Heat Go to nissan/rear mirror replacement shop Fix glass Remove old mount or install new mirror above
  3. Hi , have just joined so I can find out more about my 1991 Nissan Coupe. Its an import but would love to know if any others exist in the UK? Or indeed Europe .Nissan CoupeNissan Coupe Hope the link works but if not its in Yellow Pearl and is the same as that in the Nissan Heritage museum. Thanks in anticipation
  4. Super pro rear bushes for upper and lower control arms and panhard 10 in total £180 collected NE34
  5. Brand new never fitted £325 collection ne34
  6. Newbie to the forum hello
  7. I got a good set of used tires (4) and put em on there. $85 for just mount and balance but that’s how it rolls. Wierdest experience ever leaving the tire shop. Truck was clattering along like one or more tires seriously out of balance. I was like dreading having to go back and force the issue(s). And then within a few miles at moderate speeds the clattering went away entirely and then smooth running. Like? But that works. They put double balance weights on each wheel. They have the push ins at the inside of the wheel at the tire. And they have glue ons inside the spokes to the outside of the tire. In three cases, the weights are pretty much opposite each other on the wheels! I never saw anything like that before. Like they balanced each wheel twice? This is a very experienced tire shop, for the record. 😯
  8. UPDATE Can anyone tell me if this photo shows that the engine management light bulb is actually missing? If so can this be replaced or do I need a whole new unit? Thanks
  9. Earlier
  10. Hi. Just reg’d on here. My aunt just bought from a dealer, a 2013 ‘30th Ed’ 1.2 Micra - manual drive (which I’ve just discovered from online world is a K13, though the paperwork doesn’t state this. I drive this myself. When viewing, I asked the dealer what the thin plastic tape wrapped around a rubber pipe (possibly a manifold pipe? - sits just behind the rad’ fan and attaches somewhere under the battery plate…?) is about. He felt it and stated there’s a crack/split in the pipe and that they’d have it replaced. Before collection, by phone, the dealer advised that it wasn’t a split pipe and so doesn’t need replacing. Typhoon, I forgot what his colleague told us about it when we got there, though the gist of it was that it’s normal/standard. What they had done is replaced the thin ad-hoc looking tape with black plastic (insulation ?) tape. Any thoughts on this (tricky w/o a photo I know; can attach one tomorrow). Any K13 owners/drivers out there who recognise this? Thanks in advance.
  11. Cant find a replacement for it and no windscreen wipers mean can't drive it!
  12. Update: This it was raining today. I realized I never reconnected the drainage tube in the bottom/side of the luggage compartment so I went outside to check. What I found was: 1) The bottom of the tube (blue arrow), disconnected from the valve that goes through the metal wall of the car and into the wheel well, was not wet and there was no water pooling in the bottom of the car. This tells me the water wasn’t reaching the end of the line so it must be kinked or plugged upstream. But remember, I successfully ran a nylon string trimmer cable through the entire tube and found no evidence of dirt clogging the tube. 2) the headliner was the wettest right around the hinge for the cargo access door (red arrow). I could see a drip falling from the metal directly above it, as well as a drip running from the same piece of metal to the left, behind the upper cargo side panel trim. If the leak were coming from the moon roof drain, I don’t understand why it would be so wet all the way back where it is. Are there any other areas where water could enter on top of the car around the cargo door? The antenna for instance? It can’t be the door seal itself because the drip is above the door seal. A leak in the back of the roof still wouldn’t explain the dry end of the tube tube in the lower side panel/floor trim…
  13. Does anyone know why, when I disconnect and reconnect the battery my hardtop opens and closes perfectly, but, when I come to open it next day it won't open until I disconnect and reconnect the battery again
  14. Hi Mike, I have for sale a 2006 uk 350z with 20300 miles, and only 1 previous owner. Totaly standard car in genuinely pristine condition
  15. Thanks for giving us feedback on your Juke - its always worth hearing the bad as well as the good points to give a fair assessment of a vehicle. The Jukes have always been a high revving engine due to the transmission gearing but they are better being run at higher revs most of the time to keep the engine from carbon/sooting up, etc
  16. Sounds like water ingress into the electronics or sensors (not sure how deep the water was). If it is allowed to dry out in the sun then possibly it may work then.
  17. Hi again. I took the car for a retest today after having changed spark plugs and oil and adding additive. Emissions are now fine, however, it brought up a previous fault code P03033 which was still on the system although the engine check light was not lit. It turns out that the engine check light never comes on. The centre will not pass the car until I get this sorted. Any advice please?
  18. I have a Micra Sport C+C Auto. The drivers side quarter light window has dropped into the car body. My garage says I need parts they cannot access. Can anyone help me please? Regulator 83720BC000 Motor 83730BC000 Thank you. If no one can help me then I could well be offering this as a parts bank!!! Regards Jan in Sudbury
  19. I have a Micra Sport C+C Auto. The drivers side quarter light window has dropped into the car body. My garage says I need parts they cannot access. Can anyone help me please? Regulator 83720BC000 Motor 83730BC000 Thank you. If no one can help me then I could well be offering this as a parts bank!!! Regards Jan in Sudbury
  20. This is more than likely from the front underside but worth looking underneath at both ends to ensure that your undershield is present at the front/rear
  21. possibly the DPF trying to regenerate but something is stopping the process - check all necessary conditions with the process (e.g. fuel tank of fuel, higher RPM for set period, etc)
  22. I tend to enter details into EuroCarParts or eBay sites to see if they are listing belt or chain for each engine type If in doubt about belt replacement history then changing it is the best way forward
  23. Good luck in your search and may be worth considering countries like Malta, Cyprus and maybe Portugal for any that were sold out there in RHD and they would be in rust free condition and no tax to pay as they are old vehicles
  24. I have always managed to find replacement resistor packs for most cars on eBay More than likely would be the same for most Nissan models - remove it and compare to images of them on eBay
  25. I would ask your local Nissan dealer as to cost and availability of the parts and go from there If its a reasonable price for parts and fitting then would be worth fixing it
  26. Hi.....welcome to the club Good to have you onboard!
  27. I have been told by my nissan dealership the CVT unit is not servicable by them. Nissan GB seem to sy different, fluid change at 90k, and level checked on intermediate services. my 2018 Juke CVT unit is terminal, over 6k to fix!
