Hi all! ๐๐ป I'm currently having a massive issues with my micra k13 2013 acenta. The internal heater blower only lets through a teeny tiny amount of air. So far we have tried: Checking fuses and relays all are working - still the same Replaced pollen filter - still the same Replacing resistor with 2 other ones - still the same Replacing the heater blower fan by taking the whole front dash out (not fun!) - still the same When standing outside the car and the fans are switched to an on position you can hear the noise like the fans are on inside the cab but still a teeny tiny amount of air is coming through. What else could it be as we are at our wits end. Any suggestions are welcome please ๐ ๐ Thank you for taking the time to read this, it is very much appreciated
Iโm looking to buy a replacement wheel for my Micra Special Edition 25. As you can see in the photo itโs an 8 spoke alloy and 175/60R15. Could anyone advise where to get one from please? Thanks in advance!
Hi - welcome to the Club Fine looking Juke, not so sure I would manage to keep that paintwork clean all the time ๐ Good to have you onboard!
Hi Trevor - welcome to the club good to have you onboard and enjoy your Qashqai ๐
It would seem, and I would wholeheartedly agree. Although, technically, you could leave all previous weights on a wheel for forever, and just keep balancing it with additional weights as necessary!??? ๐ Not the case here though. All the weights are fresh new. They put both push on weights and stick on weights. Push on weights went to the inside of each wheel. Stick on weights are to the outside behind the spokes on the aluminum mag wheels. And.. as stated.. opposite each other in three of the four, and about 2 hours on the clock location off opposite on the fourth. Itโs very weird. I have personally balanced a lot of motorcycle wheels in my life.. and itโs always one weight.
Thank you
Thanks again. Iโve put in new batteries and tried the other fob for a while before. It is so random I am wondering if the door keyless buttons send a signal like the fob or they are hardwired. Iโm thinking possibly the rf receiver is getting old and cranky like the rest of usโฆ.
