  1. Last week
  2. Or off road trips near me?
  3. Hi all I have a 2011 Spanish built truck that’s being difficult at the moment. While driving it will lose complete power as seen in the video but I can turn it off and on and it will temporarily fix the problem. It’s the model with the electric waste gate and I have replaced as many sensors as I can find and I’ve also replaced the injectors and waste gate it self. As you can see there’s no warning lights on the dash or codes on the reader. https://drive.google.com/file/d/1d8qYl_jnsE9DAU_9R3ntDzCkfwC4Oz33/view?usp=drivesdk https://drive.google.com/file/d/11e5PCfRGUoEeQnFnB0VEUwoW9hifNtm2/view?usp=drivesdk anyone struck this problem? cheers Lucas
  4. Please please help! Everytime I start the car, Spotify automatically starts playing. I’ve spoken with Apple and Vodafone and they say it’s a car setting. I’ve just spoken to the Nissan dealership and they said “… they all do it, even our courtesy cars”! There must be a fix, this is the only car I’ve ever had that does this, very frustrating. Any help appreciated TIA
  5. Hello everyone Guys I am desperate. I can't find the engine number in any way. Can you help me? Owner of a Pulsar dci diesel Thank you guys
  6. Hi all! 👋🏻 I'm currently having a massive issues with my micra k13 2013 acenta. The internal heater blower only lets through a teeny tiny amount of air. So far we have tried: Checking fuses and relays all are working - still the same Replaced pollen filter - still the same Replacing resistor with 2 other ones - still the same Replacing the heater blower fan by taking the whole front dash out (not fun!) - still the same When standing outside the car and the fans are switched to an on position you can hear the noise like the fans are on inside the cab but still a teeny tiny amount of air is coming through. What else could it be as we are at our wits end. Any suggestions are welcome please 🙏 😊 Thank you for taking the time to read this, it is very much appreciated
  7. I’m looking to buy a replacement wheel for my Micra Special Edition 25. As you can see in the photo it’s an 8 spoke alloy and 175/60R15. Could anyone advise where to get one from please? Thanks in advance!
  8. Just taking a sec to say Hello, Just bought a Nissan Micra K12 1.2 2008 for my daughter.
  9. Hello I am looking for a Nissan SD25 Diesil engine which is out of a Nissan 20 Forklift. I am told the same engine was used in Nissan Cabstar and Nissan Bluebird vehicles in the 1980s. Our currant engine has a hole in the block so I am looking for a good block or a complete engine. Many thanks Colin
  10. Earlier
  11. I would definitely advise to return the car to the garage who fitted the clutch for them to diagnose the issue - could be an adjustment required or a faulty part, etc?
  12. Hi - welcome to the Club Fine looking Juke, not so sure I would manage to keep that paintwork clean all the time 🙂 Good to have you onboard!
  13. Make sure all sensors on the grill and windscreen areas are clean as dirt obscuring the sensors can result in this occuring
  14. Hi Lewis - welcome to the club Looks like a good spec Navara Major thing to have checked is the chassis for corrosion or cracks and believe the dealers have a recall and modified brackets to weld in (if it hasn't already been done)
  15. Hi Trevor - welcome to the club good to have you onboard and enjoy your Qashqai 🙂
  16. Hi guys n gals Has anyone attempted to retro fit roof rails to a 2022 model ?
  17. I'm having trouble finding the front turn signal (original two-phase) on the left side of the Nissan Pathfinder 2002, does anyone know where to buy one?
  18. I have a 2019 xtrail t32 2019 tekna and looking to put in a viofo dashcam with parking mod and hardwire it in does any one what fuse to plug in for permanent power when car is park and fuse when car is running
  19. I had the 1 litre engine in my last Juke. Its turbocharged so there is no loss of power. I now have a 1.6 Hybrid which is more cost effective especially around urban areas.
  20. I have a 2019 xtrail t32 2019 tekna and looking to put in a viofo dashcam with parking mod and hardwire it in does any one what fuse to plug in for permanent power when car is park and fuse when car is running
  21. I've been re-bushing the suspension on my Sunny Coupe and dicovered how rusty the brake splash shields are but I cannot find replacments. Do you know of someone who might have them?
  22. I would say it is more likely to be a gummed up turbo vanes fault which can be rectified by cleaning the turbo with a specialist cleaning solution (link below) https://www.ebay.co.uk/itm/292493130747?_skw=turbo+cleaner&itmmeta=01JTSXMZ9VE9ZW9F2H1DCM6423&hash=item4419f2fbfb%3Ag%3Ab9sAAOSwYutasp0A&itmprp=enc%3AAQAKAAAA0FkggFvd1GGDu0w3yXCmi1fpV%2F8bmO6dppPkpUyUyyrTVatA%2BtxVHfyIQW%2BFrQfBfOZwB9GXDgirF%2FZx1wYQ5QWHnndTFW8dxHQnQwE2DJPM593%2FytgJBS5MLBDp8GWH%2FZutClKfIZWQSfoKddANZ7zaeBnZAo6VVmNaP6AcQjlZrAqIw0vsohppQpa1TRGcxd4sUcRwemDzU%2FgJBiFCwMC0j2OXXqnhoSWOhG9lxLcC0VLM4FFWpJ0NKLa%2FFsrMcFmbgwWZs209wAa7IvVnY8g%3D|tkp%3ABlBMUIL1073WZQ&keyword=turbo+cleaner&sacat=0&relatedSearch=true Once you have cleaned it and the vanes are free to move then a good italian tune-up should blast out any residue and carbon and should then run smoothly
  23. I would say that is an air conditioning system sensor - possibly system pressure sensor?
  24. okay, best bet really.....let us know how you get on with it
  25. Hi .... and welcome to the Club Great to have you onboard and feel free to post and answer any questions you feel able to answer. The Juke is a great car, my wife has one and just keeps going with minimal repairs (if any) but always maintained to keep it reliable.
  26. Here's a problem to bake your noodle. 1995 k11 Micra, not been driven for a month, 4 new problems have appeared, all lights. 1) left headlight not working. 2) left indicator telltale light not working, either in telltale or hazard mode, external lights all working and relay clicking. 3) handbrake warning light not working. 4) reversing light not working. I'm going to do all the usual checks, starting with the external bulbs, but these systems can't have anything in common, can they?
  27. What colour? there is a set of black seats on eBay at the min. item number is 316640688205
