Hi I'm looking to get a driveaway awning for my Nissan sereena highway star Does anyone know what make would fit it ? Thanks Cath
Very random , but was just reversing and then saw this on my camera . Is it from my car ? I think not but please can someone reassure me .what should the underside look like ?
Hi everyone l brought this Nissan Note Auto 2011 in October 2024, l paid over the price as l have discovered . The Car dealer l got it from has now closed. The ignition and barrel needs to be replaced l have a wrist fusion and cannot switch it into Park and the light comes on to say l have not locked it, and many times l have drained the battery. l love the car but need advice please. Should l sell it and loose lot of money or try and get it repaired.?
Hi all I'm having trouble finding a new resistor module, at a reasnoble price, for the fan blower motor Nissan pixo 2012. Currently only works on num4. Can anyone advise if any parts from the micra or similar, are usable/transferable? Maybe even the suzuki Alto? I found one from Vospers for the Pixo, but it's £63, and I'm not willing to pay that just yet! Also, can anyone advise if the motor is serviceable?? I know you go in via the glove box side and, as its still partially working, is it fixable?
My brother once owned a 1984 Nissan Pulsar, silver colored and I believe it had an automatic transmission. I'm now retired and wondering where could I find a very nice, low mile, garaged, nice example of a first generation Pulsar NX ? I'm sure I will learn the meaning of patience as it could take years to find a truly nice condition low mile Pulsar of that era. I do keep an eye out generally on internet but hoping there are specific places, such as car clubs? events where these kinds of cars gather? My guess is they are not considered collectable and probably most have rusted away in wrecking yards by now.
Recently purchased a NV200 and I have driven it for roughly 170 Miles. I had some dash light come on and my change gear notification light kept flashing. The van then goes into limp mode, I reset the codes and didn't happen again. This happened at roughly 160 Miles and then again at roughly 165 Miles. Here are the fault codes...Can anyone help if its an easy fix I can do? Basic OBD2: P1453 (Pending) (Confirmed) - Manufacturer-specific code Freeze frame Calculated load: 65.1 % Coolant temperature: 77 °C Intake manifold pressure: 31 PSI Engine rpm: 2900 RPM Vehicle speed: 71.5 mph Intake air temperature: 27 °C Air mass value: 79.28 g/s Fuel rail pressure: 15011 PSI Distance driven since diagnostic trouble code cleared: 18.6 miles Engine: P1453 - Diesel Particulate Filter Differential Pressure Control Function: Performance or Incorrect Operation ABS: C1130 - ENGINE SIGNAL 1 Thanks Dan
I owned a couple of Quashqais through 2010 - 2016 then switched to Toyota for hybrid drive. I went back to Nissan in December 2024 and purchased a Juke Hybrid. I'm happy with the high and safe-feeling drive of the car but a bit disenchanted with some features I find irritating. In particular the Nissan Connect Data Transmission screen which requires accept or decline every time I start up. Nobody seems to have found a way to disable this. Lots of audible warnings - though I sense most new cars have this now. Anyway, I look forward to putting a few miles on the clock this year. Happy to be here and I'll keep an eye out for useful tips.
Hi everyone What do all models of the pulsar have? The 1.2 petrol, 1.5 diesel and 1.6 petrol? Are they timing belts or chains and what are the intervals for these to be changed at? Thank you
Hi. I’m new here. Quick question about tire matching. The new AWD cars require tread depth tire matching in order to not mess up their AWD systems. I have an 05 Pathfinder LE 4WD version. This has the drive selection for 2WD, AWD, 4WD and 4WD LO. I don’t use anything but 2WD. I understand that, in 2WD the rear wheels are active and that it’s best to tread depth tire match that rear axle. But, since the front is not engaged, is tread depth tire matching required in the front if only 2WD is ever used? I know best practices and all that, but I have a bad front tire and the other side is well worn. I was thinking of just running the new full size spare.
Thank you I will pass that on
I removed the inside panel of the boot door and saw no signs of damage to the wiring. And I was wrong about the camera being connected to the right side light. Seems to have its own circuit. So I’m none the wiser for now. I have ordered a new camera (cheap one from Aliexpress) and will try and connect that before messing around more with the wires.
Service Fault on 2016 Pulsar - how to diagnose
Trevor replied to Morty's topic in Nissan Pulsar Forum
First thing I would do is to go around the car and clean all the external sensors and cameras (including front screen ADAS) -
Battery condition ? Air leak in intake system - split hoses, etc COuld be a number of things - best to get it scanned to narrow it down
