  2. Yesterday
  3. Thanks mate will do. Need to find a few bits and bobs but the car is mechanically sound.
  4. Thanks again. I’ve put in new batteries and tried the other fob for a while before. It is so random I am wondering if the door keyless buttons send a signal like the fob or they are hardwired. I’m thinking possibly the rf receiver is getting old and cranky like the rest of us….
  5. no that seems fine as long as the lights switch on and off I wonder if the drivers door lock is faulty as it should control the rest of the doors locking and unlocking The fob may be faulty but try a quality battery and also check any microswitches for the buttons that may have become detached from the circuit board
  6. Tried all the doors, they all put light on with a delay. Boot and tailgate both put light on and straight off. Is this the issue?
  7. Thanks Trevor I will test this tonight.
  8. It is necessary to remove all weights if out of balance before fitting new ones when replacing tyres If the amount of weights are too large then it is sometimes best to spin the tyre around on the rim to cancel out the imbalance
  9. I would check the door switch which signals the system that the door is opened or closed and can trigger the alarm if wrong signal given Open in each door including bonnet, load area and all others to see if the interior light comes on and goes out after a while
  10. Hi....welcome to the Club
  11. Hi....welcome to the forum Good to have you onboard
  12. oh very nice car ! Welcome to the forum and keep us updated on the progress
  13. I would start by checking the electrical connection into the motor and if it spins up when you turn everything on the there's the problem
  14. Any idea what it could be though?
  15. I would start by removing the glovebox to see how much access you gain, if not much then continue to remove more dashboard components
  16. After some help. My air blower is intermittent, some tomes it works sometimes it doesn't. Fuse has been checked, not sure if a new fan is required? Do you get to it by taking the glovebox out rather than the whole dashboard?
  17. Last week
  18. Any ideas?
  19. I am looking for an idea of what the cost of replacing both front and back brake pads and discs for Nissan Qashqai 2019 model ? Thanks
  20. Hi. (This site isn’t allowing me to select the Micra Forum). Just acquired (legally) a 2013 K13 Micra, which came without parking sensors. Online options are so numerous, what a minefield! Any advice out there? Anything gratefully received.
  21. Hi, I am in the process of replacing the timing chain and sprockets on my 2015 Pulsar (70k miles). I'm now at the point of taking the sprockets off the camshafts but not sure how I do this. Is is just the bolt in the centre of each sprocket that needs undoing? Standard thread for both? I also now need a workshop manual to find all the torque settings as part of the rebuild. Can anyone provide a link or suggest a good manual to buy? Of course, if anyone has a list of the torque settings they could share, that would be perfect! Finally - any ideas what may have caused the chain and sprockets to wear at this low mileage? The chain had stretched and was noisy. On removal I've noticed the tensioner was ok but the chain was clearly stretched and all sprockets are well worn - particularly on the crankshaft. I have only owned the car for the last 2 years and the car had been regularly serviced prior to that. Sorry for all the questions on my first post but I appreciate all responses. Thanks
  22. Hi all new to the group just wanted go introduce myself. I’m Adam and I’m in North Yorkshire I have a 02 Nissan 350z that I was recently given by my dad as it’s been sat for 2yrs. it had a little work done before it got parked up but it still needs a bit of love. tell me what you think.
  23. Hi all, I have a 2013 D40 Tekna with a factory-fitted reversing camera which is sited under the handle to open the boot/cargo area. The handle has broken and I cannot find a replacement anywhere. All the ones I can find are standard, without a cutout for the camera, which won't fit - I have attached pictures to show the cutout. Has anyone ever had to replace their handle, and been able to find a suitable replacement?
  24. Earlier
  25. Hello all, I am new to here and hope you can help, my qashqai has developed this issue when starting in the morning, it struggles to start with a funny turning over sound and eventually when it starts there is alot of white smoke and it idles rough but once it is warm it runs perfectly but with still a bit of smoke, I have been looking around the net, I have seen leaking or faulty injector a clogged up PCV valve I did have the Egr valve changed last year that’s all good. It dose feel like it has loss of power but the turn dose feel like it kick still. When it’s warm it sound spot on, by the way it has done 117k,
  26. Hello. I’m new to the forum. Can anyone help? my 2007 pathfinder (my pride and joy) has started requiring me to randomly unlock it from the passenger side and then silence the alarm with the fob. Normally it works fine from the fob or the door buttons but then it randomly stops working. Once unlocked it goes back to working again for a while. I’ve changed batteries etc but I am out of ideas. Thank you
  27. Hello. I need to remove the original rear vision mirror mount from my nissan pulsar c12 2013 model as the mirror has broken off the mount and I need to replace it with a universal replacement and a glue strip. The mount is glued on and not clipped like the modern mirrors. I have tried breaking the seal gently with a screwdriver and blade but it has damaged the glass on the underside of windscreen. The cracks have not reached the upper surface. I have now tried using string to cut into the seal but i cannot cut right through the seal and it is shearing on glass fragments. I'm wary of using the hairdryer to soften the glue as it may cause more cracks. Any suggestions please? I had thought of using solvent but not sure which is best for this older adhesive. My options are: Fishing line/piano wire to saw through the seal Solvent Heat Go to nissan/rear mirror replacement shop Fix glass Remove old mount or install new mirror above
  28. Hi , have just joined so I can find out more about my 1991 Nissan Coupe. Its an import but would love to know if any others exist in the UK? Or indeed Europe .Nissan CoupeNissan Coupe Hope the link works but if not its in Yellow Pearl and is the same as that in the Nissan Heritage museum. Thanks in anticipation
