Michaelww33 joined the community
Dciw joined the community
Billj joined the community
Nigel Hanlon joined the community
Toonarmy joined the community
Brian Millbank joined the community
yumm joined the community
ade555 joined the community
Micra 1.2 30th Edition joined the community
Stewart Hay joined the community
Πέρασα μέσα από πολλά νερά και δεν βλέπω τις κάμερες και το τυφλό σημείο αναβη το λαμπάκι του διακόπτη .
