yumm joined the community
ade555 joined the community
Micra 1.2 30th Edition joined the community
Stewart Hay joined the community
Stephen Woodfinden joined the community
abyancahvs9685 joined the community
colin woodroffe joined the community
Woodsmith joined the community
Derek Stephens joined the community
CVTNZ2010 joined the community
Πέρασα μέσα από πολλά νερά και δεν βλέπω τις κάμερες και το τυφλό σημείο αναβη το λαμπάκι του διακόπτη .
Trevor started following Front tire matching 2005-2012 , Is this from my car ? , Help understanding fault codes please. and 2 others
I would imagine if the front hubs are manually unlocked then it should be fine but if auto locked hubs then potentially the different rolling diameter would affect the transfer box, etc....so probably worth ensuring all four tyres are same tread depth as near as possible
