Adwozere joined the community
Edwina started following 2001 Nissan Micra for sale
Edwina joined the community
Simon Nelson joined the community
Very random , but was just reversing and then saw this on my camera . Is it from my car ? I think not but please can someone reassure me .what should the underside look like ?
genkijen joined the community
Hi everyone l brought this Nissan Note Auto 2011 in October 2024, l paid over the price as l have discovered . The Car dealer l got it from has now closed. The ignition and barrel needs to be replaced l have a wrist fusion and cannot switch it into Park and the light comes on to say l have not locked it, and many times l have drained the battery. l love the car but need advice please. Should l sell it and loose lot of money or try and get it repaired.?
Jenny joined the community
Pantelis started following Fan blower resistor
Hi all I'm having trouble finding a new resistor module, at a reasnoble price, for the fan blower motor Nissan pixo 2012. Currently only works on num4. Can anyone advise if any parts from the micra or similar, are usable/transferable? Maybe even the suzuki Alto? I found one from Vospers for the Pixo, but it's £63, and I'm not willing to pay that just yet! Also, can anyone advise if the motor is serviceable?? I know you go in via the glove box side and, as its still partially working, is it fixable?
curvecrazy started following 2005 Pathfinder Tire Matching
My brother once owned a 1984 Nissan Pulsar, silver colored and I believe it had an automatic transmission. I'm now retired and wondering where could I find a very nice, low mile, garaged, nice example of a first generation Pulsar NX ? I'm sure I will learn the meaning of patience as it could take years to find a truly nice condition low mile Pulsar of that era. I do keep an eye out generally on internet but hoping there are specific places, such as car clubs? events where these kinds of cars gather? My guess is they are not considered collectable and probably most have rusted away in wrecking yards by now.
dustball joined the community
Recently purchased a NV200 and I have driven it for roughly 170 Miles. I had some dash light come on and my change gear notification light kept flashing. The van then goes into limp mode, I reset the codes and didn't happen again. This happened at roughly 160 Miles and then again at roughly 165 Miles. Here are the fault codes...Can anyone help if its an easy fix I can do? Basic OBD2: P1453 (Pending) (Confirmed) - Manufacturer-specific code Freeze frame Calculated load: 65.1 % Coolant temperature: 77 °C Intake manifold pressure: 31 PSI Engine rpm: 2900 RPM Vehicle speed: 71.5 mph Intake air temperature: 27 °C Air mass value: 79.28 g/s Fuel rail pressure: 15011 PSI Distance driven since diagnostic trouble code cleared: 18.6 miles Engine: P1453 - Diesel Particulate Filter Differential Pressure Control Function: Performance or Incorrect Operation ABS: C1130 - ENGINE SIGNAL 1 Thanks Dan
DanTheMan joined the community
James_Ucel joined the community
stellagrezza started following Nissan Connect Satnav 2014
stellagrezza joined the community
Stuart Dorman joined the community
Psalmist started following Hello - good to be here
I owned a couple of Quashqais through 2010 - 2016 then switched to Toyota for hybrid drive. I went back to Nissan in December 2024 and purchased a Juke Hybrid. I'm happy with the high and safe-feeling drive of the car but a bit disenchanted with some features I find irritating. In particular the Nissan Connect Data Transmission screen which requires accept or decline every time I start up. Nobody seems to have found a way to disable this. Lots of audible warnings - though I sense most new cars have this now. Anyway, I look forward to putting a few miles on the clock this year. Happy to be here and I'll keep an eye out for useful tips.
kazzz25 started following Timing belt/chain specifications
Hi everyone What do all models of the pulsar have? The 1.2 petrol, 1.5 diesel and 1.6 petrol? Are they timing belts or chains and what are the intervals for these to be changed at? Thank you
leeh started following Micra hardtop convertible
curvecrazy started following Front tire matching 2005-2012
Hi. I’m new here. Quick question about tire matching. The new AWD cars require tread depth tire matching in order to not mess up their AWD systems. I have an 05 Pathfinder LE 4WD version. This has the drive selection for 2WD, AWD, 4WD and 4WD LO. I don’t use anything but 2WD. I understand that, in 2WD the rear wheels are active and that it’s best to tread depth tire match that rear axle. But, since the front is not engaged, is tread depth tire matching required in the front if only 2WD is ever used? I know best practices and all that, but I have a bad front tire and the other side is well worn. I was thinking of just running the new full size spare.
Thank you I will pass that on
I removed the inside panel of the boot door and saw no signs of damage to the wiring. And I was wrong about the camera being connected to the right side light. Seems to have its own circuit. So I’m none the wiser for now. I have ordered a new camera (cheap one from Aliexpress) and will try and connect that before messing around more with the wires.
Service Fault on 2016 Pulsar - how to diagnose
Trevor replied to Morty's topic in Nissan Pulsar Forum
First thing I would do is to go around the car and clean all the external sensors and cameras (including front screen ADAS) -
Trevor started following One reverse light and the reverse camera not working and Émissions fail
The code means 'Heated Oxygen Sensor (HO2S) Heater Control Circuit Low (Bank 1, Sensor 2)' This sensor (at the back of the catalytic converter) may be faulty and is showing a low reading for the efficiency of the cat. This could be that there is a slight exhaust blow (a bad gasket / joint) in the exhaust system and this is causing the issue A rag held tight over the tailpipe at the rear of the car and listen for any hissing from the exhaust towards the front of the car to establish any leaks that may be present. (obviously Health & Safety needs observing when carrying out this test)
Morty replied to Morty's topic in Nissan Pulsar Forum
No, no accidents. Another garage ran their diagnostic tool on the car, front radar is OK, it's the lane detection/blind spot system that is a fault, can be either the front camera in the windscreen or the rear camera, my feeling is can't be the front camera for blind spot checking. At least the radar isn't at fault. Question is how to fix it from here. -
Trevor replied to bultenkarlsson's topic in Qashqai Club's Topics
Its certainly worth checking the wiring for damage as this does occur over time -
Has the vehicle suffered any accident damage recently, including the front screen? -
Battery condition ? Air leak in intake system - split hoses, etc COuld be a number of things - best to get it scanned to narrow it down
