Mickmoonie
    UK
    Pathfinder
Mickmoonie's Achievements
  • One Year In
  • Collaborator Rare
  1. My drivers door won’t open from inside, it’s a 2007 model, probably been asked by someone else in the past?
  2. Hi, my 07 pathfinder has a really rough idle speed often causing it to stall, no error codes show up, has anyone else have the same problem please?
  3. Think it shows the fitting points in the manual
  4. Does anyone know where I can get a cd eject button for my 07 pathfinder from please as mine is missing, thanks.
  5. Hi, not had chance to really look yet, what with work and crappy weather, will post when I do, thanks m8
  6. Thanks Trevor, couldn’t see a broken spring but never checked the links, thanks for your suggestions 🤘
  7. I have a 2007 pathfinder which has developed a clunk/thudding noise at the back when being driven, it doesn’t appear in reverse, has anyone any ideas please, could it be a driveshaft?
  8. Will be trying a new suction control valve, will let you know if it works
  9. Hi Daroosi, did you ever resolve your screeching central locking as my 2007 model has started doing the same, Mickmoonie 🤘
  10. Hi do you know the part number for the sensor by any chance, the cambiere one (VE375144) says it doesn’t fit my 07 model😳
  11. Thanks Trevor, I’ll phone my garage
  12. Hi, I have the same year model with a similar problem only mine restarts after stalling, by the way the idle speed seems very low, poss why it stalls so much, it also takes ages to warm up any help would be good please.
