Johnj
    Wales
    Qashqai
Johnj's Achievements
  • One Year In
  1. Hi people drove car today and going at high revs and car shudder and lost a little power but picked back up again but red engine light came on, it as done it before and the glow plugs needed changing so done them but been good up till now stoped car light went off as I started t back up but as not come back on put on reader it says glow plug in line system any ideas thanks
  2. Hi all i have a 2008 acenta, just had a new starter motor in it and now it as a squeezing which sounds like it is coming from around the alternator area it dose not make the noise when starting up it makes it as I drive but only in 1,2,3,4 gear as I speed up and go into 5,6 gear the squeezing seems to go, I did think it was the brake pads on front drivers side in which case I know need changing but as the sound as gone on for a few day it seems to be more around the alternator belt area Hi ll
  3. So it would be on the back of the radio unit
  4. Acenta 2008 , drivers door opening latch as stuck open and will not go back in so can not open door from in side door will open fine from out side with the handle lever so need to put window down to open it then any answers on this cheers
  5. Cheers will take a look at this
  6. I don’t know if been ask in past but I have a 2008 ascents just picked up a android sat nav dash cam with music player on it it is on dash board fixed lcd screen, the thing is I can not find a aux port for it to fit in to or can I get a usb to aux plug for it to work in car as I can not find one anywhere or find a right answer for it many thanks
  7. Hi all , I have acenta 2008 which dose not come with sat nav well is it possible to fit one that is compatible with this model was thinking on fitted in with cd and radio as it would be easy than just sticking one to dash
  8. As in title my car seems to shudder when I try to take off in first gear on times but only when it as been raining or the roads are wet but car is fine if the roads are dry any help on this will be great , I know it is due a old change which will be done this week but don’t think this would be the issue mind
  9. As in title , this happens when I turn the steering if the vehicle is stationary or going
