sunwalker
    sydney
    nissan lafesta Highway St
sunwalker's Achievements
  • Reacting Well Rare
  1. Does the ECU use the auxiliary battery during istop? Meaning when the engine turns off & the a/c etc is then run from the auxiliary battery during istop. I've been trying to figure out why my abs, tracking, hand brakes mil (warning lights are on) for my 2011 Nissan lafesta / Mazda 5. The fault codes from the scanner are many, but include low voltage supply, resetting the abs module worked (so far) after I charged the aux battery on repair mode for a day (need to purchase a battery diagnoser). My thinking is the car engine stops (istop) then all electrical including the ecu draw only from the aux battery, so if the aux battery is failing then the ecu turns on the mil abs etc fault lights. Is this the case? Sorry just realized I posted this in N. Leaf. probably should be in General Nissan Owners Lounge
  2. Hi can anyone recommend a diagnostic Scanner that works on nissan lafesta Highway Star 2011, for abs code reading & reset? "The Lafesta Highway STAR is simply a Mazda5 , even the interior is exactly the same, including the 2.0-liter, four-cylinder engine " So do I invest in a scanner for Mazda or Nissan? Very little info on scanners relating to it. You'd think nissan would be more customer supportive, & have a data base for this on their home page. Big let down.
