DanTheMan
    Exeter
    NV200
DanTheMan's Achievements
  1. Recently purchased a NV200 and I have driven it for roughly 170 Miles. I had some dash light come on and my change gear notification light kept flashing. The van then goes into limp mode, I reset the codes and didn't happen again. This happened at roughly 160 Miles and then again at roughly 165 Miles. Here are the fault codes...Can anyone help if its an easy fix I can do? Basic OBD2: P1453 (Pending) (Confirmed) - Manufacturer-specific code Freeze frame Calculated load: 65.1 % Coolant temperature: 77 °C Intake manifold pressure: 31 PSI Engine rpm: 2900 RPM Vehicle speed: 71.5 mph Intake air temperature: 27 °C Air mass value: 79.28 g/s Fuel rail pressure: 15011 PSI Distance driven since diagnostic trouble code cleared: 18.6 miles Engine: P1453 - Diesel Particulate Filter Differential Pressure Control Function: Performance or Incorrect Operation ABS: C1130 - ENGINE SIGNAL 1 Thanks Dan
