Hi,
I have recently purchased a Nissan Note N-Tec 1.4 (2011 Reg) and was only given 1 key with this.
I decided to purchase another key online as a spare. I purchased a used original Nissan Note key, the same as the one I already have. I was aware that the new key would have to have a new blade cut and the transponder recoded by an auto locksmith.
However, I was under the impression that the FOB on the key could be reprogrammed/recoded so that the central locking system could be activated via the FOB buttons.
Normally, there is a sequence of steps which initiate a programming mode in a car. I have come across a couple of these sequences for Nissan cars but they haven't worked for my Note (one was a sequence to enter your key in and out of the ignition 6 times but this seemed specific for US cars and didn't work for me, the other was a sequence to turn the ignition to the on position 6 times but this didn't work either - there were more steps in both sequences but, as they didn't work, I didn't think it was worth outlining the full details here). I tried the sequences several times but neither managed to activate any kind of programming mode.
There must be a sequence that works for a UK/European version of the Nissan Note 2011 reg in order to recode your fob. Would anyone happen to know if there is such a sequence available?
Regards,
Shuja
