Search the Community
Showing results for tags 'nissan note'.
Hi I have a nissan.note 2015, and the back seat handle broke as we couldn't fold it down. Now the cable has come undone from underneath...what do I do..
- nissan note
- 2015
(and 1 more)
Tagged with:
Nissan Note Premium 1.2 reg 2015 searched handbook is it normal to always have a fan running when ignition switched on I've turned all the Dashboard press buttons off but a fan ? noise is permanently running inside car concerned for battery. Second question is the idling of the Note always very weak just ticking over. I am new to Nissan Note. Finally is it necessary to put a dashcam ? thanks Music to my ear.
Hi, I have recently purchased a Nissan Note N-Tec 1.4 (2011 Reg) and was only given 1 key with this. I decided to purchase another key online as a spare. I purchased a used original Nissan Note key, the same as the one I already have. I was aware that the new key would have to have a new blade cut and the transponder recoded by an auto locksmith. However, I was under the impression that the FOB on the key could be reprogrammed/recoded so that the central locking system could be activated via the FOB buttons. Normally, there is a sequence of steps which initiate a programming mode in a car. I have come across a couple of these sequences for Nissan cars but they haven't worked for my Note (one was a sequence to enter your key in and out of the ignition 6 times but this seemed specific for US cars and didn't work for me, the other was a sequence to turn the ignition to the on position 6 times but this didn't work either - there were more steps in both sequences but, as they didn't work, I didn't think it was worth outlining the full details here). I tried the sequences several times but neither managed to activate any kind of programming mode. There must be a sequence that works for a UK/European version of the Nissan Note 2011 reg in order to recode your fob. Would anyone happen to know if there is such a sequence available? Regards, Shuja
- 2 replies
- fob coding
- fob programming
(and 3 more)
Tagged with:
