Marmaduke1 Posted December 14, 2013 Share Posted December 14, 2013 My wife has a Nissan Pixo1.0 which has done 15000miles. When the clutch is engaged in first gear at higher than normal speed e.g. on a hill start there is quite a loud squealing noise presumably from the clutch. Any suggestions as to what the cause might be? Is it a worn clutch after such a short period as my wife is a careful driver! Link to comment Share on other sites More sharing options...
Nissan Owners Club Posted December 16, 2013 Share Posted December 16, 2013 Could be something like the clutch release bearing? Is the car still under warranty? Link to comment Share on other sites More sharing options...
Marmaduke1 Posted December 16, 2013 Author Share Posted December 16, 2013 Could be something like the clutch release bearing? Is the car still under warranty? Link to comment Share on other sites More sharing options...
Marmaduke1 Posted December 16, 2013 Author Share Posted December 16, 2013 Unfortunately not under warranty by 6 months. I noticed the noise while it was still under warranty but foolishly did nothing about it as I seldom drive the car. Seems like it will be an expensive job? Link to comment Share on other sites More sharing options...
Nissan Owners Club Posted January 2, 2014 Share Posted January 2, 2014 If it's the clutch release bearing then it's the same as replacing the clutch with the whole assembly coming out. It can be good practice to change the clutch at the same time or at least examining the wear. Shouldn't be worn out after that little mileage though. Have you tried getting a garage or mechanic to diagnose it for you yet? Link to comment Share on other sites More sharing options...
