Hi,
only had our LEASE Note for 4 weeks so far.
1.5 DCi n-tec.
Just done whole tank from brim-to-flashing WITHOUT resetting
the mpg reading. (1600 miles so far but playing with the
mpg thing to test driving styles etc :-) )
The reading on the Speedo was 71.3,
CALCULATING miles/gallons gives 65 !
[ Chelmsford to Dagenham 6 days plus local shops and
couple of short trips - for info ]
Either Nissan wants you to think it's better than it is,
or,
it's about 10% innaccurate (spl?) possibly because it's dealing
with very small flow of Diesel and such high Miles ?!?!?
That said, it's only a minor complaint. The car is brilliant :-)
Enormous inside / smallish outside.
Not the fastest thing on the planet but far more tractable than
some of the other little economy cars i tried (the corsa 1.3 CDTi
was DEAD below 2,000 rpm).
The CONNECT thing is brilliant too, considering it's so compact
it does so much ! It has 'gliched' once so far when it seemed
to 'lock-up' if i tried to play an mp3 - had to turn ignition
off to reset it.
Enough for now,
FatS.
