Is it possible to change the double DIN bluetooth 6 disc in dash equipped Micra K12 to a Connect Navigation unit?
Obviously the GPS antenna will need to be added but are the other plugs the same and will it have to be "matched" to the car?
  • 6 years later...
Pity you had no replies iam doing same with a k13 - put sat nav in works but need wiring altering and Nissan security blocks unit after 5 mins because not matching Vin numbers - trying dealer to have unit reprogrammed.
