Micra 1.0 16v
Hi can any one help my daughter's micra keeps cutting out as you drive it  it as if the key s being turn on and off very jerky then it will be ok for 30 seconds then do it again.  Its had new ht leads distributor cap points coil. im sure its an electrical problem because its intermittent . garage has looked at it and there stumped .
Hi Paul,
It sounds very much poor earth connections, worth checking the earth lead from the battery to the engine/gearbox as Nissan's tend to suffer from this.
Regards   Trevor
