Hey Guys
I have a 2015 Qashqai, theres an annoying rattle / squeak coming from around the instrument cluster where the rev counter etc is located. When the noise starts if you hold the cluster / dash area it stops it so I'm assuming its something to do with plastic on plastic in that area. I was going to remove the instrument cluster and put some foam tape around th areas that touch but there is no obvious fixings in that area. Any one had the instrument cluster out ?
Thanks
Hi...and welcome to the Forum!
Not removed one personally but would imagine it's a case of removing the instrument cover and then unscrewing the panel.
Great idea of using the foam tape.  Let us know how you get on with it
Cheers,  Trevor - Admin
Hi Trevor
Do you know how to remover in instrument cover ? There are no signs of any fixings, Its likely that its this cover that is causing the noise :)
Thanks
Apparently it is held on by two clips to the front and five more metal clips towards the back and comes away in two halves
