eljay Posted October 9, 2016 Posted October 9, 2016 Hi, Can anyone help me? I have a 2001 (Y Reg) 1.0L Micra. The Drivers wiper-spindle is "dropping"/sloppy in its pivot/bush in the triangular plate. (The plate also has a captive bolt slipping, so it will have to be cut off). Is this plate/pivot/spindle-bearing available please? Is it possibly repairable? Thanks
Trevor Posted October 13, 2016 Posted October 13, 2016 Hi...welcome to the Forum I would advise cutting it off and replacing with a secondhand one (if in good condition) as the cost of new (if available) would probably be a false economy. Cheers Trevor
eljay Posted October 18, 2016 Author Posted October 18, 2016 This looks right.....but it is not cheap. http://www.buycarparts.co.uk/metzger/7081045 Has anyone ever fitted one?
Trevor Posted October 20, 2016 Posted October 20, 2016 I've fitted something similar before but it wouldn't have been on a Nissan...easy enough to fit I would assume as long as all nuts, bolts, etc come off easily.
