Sylarwolf Posted December 1, 2016 Share Posted December 1, 2016 Hello I am having trouble diagnosing a fault with my front offside indicator. When I indicate it uses the side light instead of the indicator light. It is not the bulb as that has been changed. It has been like this for a while now and has caused an MOT failure. The garage mechanic doesn't know what could be the problem and has suggested I get an electrician to look at it. I am having a hard time finding an electrician with a good knowledge of cars. Does anyone have an idea of what the fault could be? Thanks Quote Link to comment Share on other sites More sharing options...
Trevor Posted December 7, 2016 Share Posted December 7, 2016 Hi....welcome to the Forum Sounds like it could be an earth issue or the wrong indicator bulb fitted which is causing it to backfeed into the sidelight You could prove this by swapping the indicator bulb over to the other side and if the fault appears over there then you have the wrong bulb fitted Let us know how you get on with it Cheers Trevor Quote Link to comment Share on other sites More sharing options...
