Ivan Posted January 28, 2017 Share Posted January 28, 2017 hi guys it's Ivan, I have a Nissan primera 2.2 dci primera, had egr valve stripped and cleaned replaced turbo boost solenoid valve, ran ok for 4 months but now getting a power dip when accelerating it will red line in second but third and fourth gear power dips at 4 thousand revs take your foot off and accelerate again and it will red line again not that I drive it like this. Any ideas would be welcome I was thinking maybe maf sensor ? But tickover is not fluctuating it's nice and steady at 600 rpm any ideas would be appreciated. Quote Link to comment Share on other sites More sharing options...
Trevor Posted January 30, 2017 Share Posted January 30, 2017 Hi Ivan...welcome to the Forum I think your theory about the MAF sensor is about right..you should just be able to replace the sensor itself as opposed to the housing it is within...slightly cheaper sometimes! Definitely check fault codes first to see if there is mention of the MAF sensor. Cheers Trevor Quote Link to comment Share on other sites More sharing options...
Ivan Posted January 30, 2017 Author Share Posted January 30, 2017 Thanks for your advice Trevor. Quote Link to comment Share on other sites More sharing options...
