X Trail 2015 passnger door wont open from inside
awtofpw
The front passenger door on my 2015 X Trail wouldn't open from the inside.  This wasn't a gradual fault.  It happened from one journey to the next.  After some research I have found the problem and fixed in five minutes.
The same lock is used on the front and rear doors.  The front doors therefore also include a child lock switch that is inaccessible.  This inaccessible switch moves under car vibration over time.  To solve the problem simply remove the three lock fixing screws with a T30 screwdriver.  Move the lock slightly and you will see a white sliding switch which is the covered up child lock switch.  Move it to the opposite position (confirm by looking at rear lock) and viola....
I first saw this solution on a Qashqai form and I discussed with a)Nissan UK  b) Ancaster Nissan Bromley and c)Ancaster Nissan Eltham to confirm.  They ALL denied that the same lock was used and all denied that this could possibly be an issue!!  This is my typical experience of these Nissan main dealers.......ie they don't have a clue about the product they claim to be expert in.
Hi....welcome to the Forum
That's incredibly useful information and thanks for sharing it with us.
Seems logical to use same locks all round but at least disable the child lock feature....potentially a huge safety issue if you can't exit the car in case of an emergency.
Cheers  Trevor
  • 6 years later...
Amazing advice.
This has literally just happened on my Xtrail, True enough, I loosened the 3 trox bolts so I could fit a little hook in the recess to enable me to pull the child lock switch back. Bobs you uncle and Fanny’s your aunt it worked Thank you.
  • 4 months later...
