Sandeep Singh Posted August 19, 2017 Share Posted August 19, 2017 Hi All, I have Nissan Micra K13 2011. I am facing issue with the beep sound. The beep sound is not working whenever I use indicators or when the insert the key in ignition and open the door the beep sound doesn't work. I approached Nissan Service center for this issue, they said that there is a problem with the instrument cluster which needs to be replaced. I am sure there must be something else which is causing this issue. Any help or tip would be appreciated. Thanks Link to comment Share on other sites More sharing options...
Trevor Posted August 21, 2017 Share Posted August 21, 2017 Hi....welcome to the Forum Sounds like it is a fault with the sound unit rather than a wiring issue. Quite possibly could be an instrument cluster issue but be aware of cost as this unit is the gateway for the CanBus and it could be quite expensive and would need to be coded in at a cost also. Let us know how you get on with it Cheers Link to comment Share on other sites More sharing options...
