andybaz Posted September 4, 2017 Share Posted September 4, 2017 hi all, i understand the primeras runs the same QR20DE engine, i have replaced my crank sensor, but looks like a chain issue, currently looking for a good website link for chain replacement, any pointers or views greatly appreaited. Link to comment Share on other sites More sharing options...
Trevor Posted September 6, 2017 Share Posted September 6, 2017 Can't find much either on the web only this one https://www.justanswer.com/uk-nissan/33dj8-set-timing-nissan-qr20de.html Have you established that the chain has slipped ? Link to comment Share on other sites More sharing options...
andybaz Posted September 14, 2017 Author Share Posted September 14, 2017 Well ... its currently bad news, after i replaced the crank sensor the car went fine - then P0335 pops up gain - so a full chain kit including VVT gear was ordered, yep take a look at ebay prices ..... so after paying £460+ for chain replacing ..... about 50mile later the light is back on - code P0335 crank position, which leaves 2 options now - as suspecting there is nothing wrong with any of the chain timing gear and the thoughts are - Either my crank sensor went deffective, the wiring loom that feeds the sensor is damaged somewhere and finally its the camshaft sensor and not the crank sensor. So its back at the garage to have a 2nd new crank sensor & its 1st new cam shaft sensor fitted and see how we go. Link to comment Share on other sites More sharing options...
Trevor Posted September 15, 2017 Share Posted September 15, 2017 That's bad news but on the upside...at least the camchain is now replaced and less likely to just fail in service so peace of mind there. If the cam sensor is faulty then this can flag a code but equally if the chain has any slack in it still then this also could be a likely cause Link to comment Share on other sites More sharing options...
