NISSAN MICRA K13 WONT START (2013 MODEL)
anderten
I've come to ask for help !! A week ago my car was down, after taking it to the mechanic it was found that there was water in the engine! so the dome gasket was gone, so it replaces the following parts: fuel pump, complete engine repair set, covers, segments and spark plugs.
After so much expense with parts, the car does not pick up, the spark plugs come on but it still does not catch! The mechanic thinks that there may be enough with the current of the candles not enough and I'm in this situation! Any idea?
We remove the spark plugs and check that the fuel is reaching the spark plugs.
Any ideas?
thank you
I would start by looking at the battery condition, connections and earth connections to the chassis.
After that, I would look at other obvious areas, such as ignition immobilisation and fuel inertia switch.
such as ignition immobilisation and fuel inertia switch?
where do i can find that part?
the energy comes to the spark plugs!
The battery has a good charge, I even tested it with the multimeter.
the car arrived at this point because the cupula gasket burned and water got into the engine!
