Infiniti G37 brake noise.  Only after braking do I get a nasty noise from the front of the car. If I start driving and manage to only brake lightly, no noise?  I know much of the car comes from ZX bin store.  Any suggestions please?
Sounds like the pads have worn to the audible wear indicator (thin strip of metal that contacts the discs to alert you of the impending low pad friction lining)
....or pads are sticking in the carriers...need to remove, clean up, lube up (with copperslip or similar) and refit
