Dannydashcam Posted March 24, 2018 Posted March 24, 2018 Im after fitting a standard rev counter or after market rev counter but ive dismantled the clock housing and cannot find where to connect the standard revcounter and i cant source a aftermarket 3 cylinder one .. anyone any advice cheers... new member
Trevor Posted March 27, 2018 Posted March 27, 2018 Any digital rev counter should work and maybe the best bet would be to run one through the OBD socket which will output engine information which can be displayed. Here's a link to one that will work on a 3 cylinder https://www.ebay.co.uk/itm/Universal-12V-2-52mm-Digital-Rev-Counter-Tacho-Tachometer-Gauge-Red-LED-Light/122562255286?hash=item1c894799b6:g:mScAAOSw9~5ZTPQv
Dannydashcam Posted March 27, 2018 Author Posted March 27, 2018 Thanks for that Trevor, I'll have a good look at it. Ideally wanted the clock style but may settle for this if I can't sort it. Cheers
Reda Posted October 18, 2022 Posted October 18, 2022 On 3/24/2018 at 2:41 PM, Dannydashcam said: Im after fitting a standard rev counter or after market rev counter but ive dismantled the clock housing and cannot find where to connect the standard revcounter and i cant source a aftermarket 3 cylinder one .. anyone any advice cheers... new member Expand Hi there, I’m planning to install one too (the oem one). I’m struggling to install it, can you tell me where you managed to install all the cables ecc. Please :)
Register a new accountSign in
