pancho Posted August 29, 2018 Share Posted August 29, 2018 2002 T30 ( 2.0 petrol) The ABS and 4WD warning lights come on intermittently. Usually after starting engine. Switch off and on again and the fault clears. Is this a common fault? If so, does anybody know the cause please? Pancho. Link to comment Share on other sites More sharing options...
Trevor Posted August 31, 2018 Share Posted August 31, 2018 Would be worth checking your chassis earth return leads....found a couple of them sheared off on my X-Trail. Look down by the underside of the gearbox to where they connect to the chassis....replace if necessary (cheap and better replacement earth straps in Halfords...did the lot for £10) Link to comment Share on other sites More sharing options...
