Sump removal
den9112
Hi , my daughters 2004 1.2 SE as  a small sump leak that was picked up on at it's MOT...The mechanic said he patched it up and it was Ok charged her £40 to do it .
However i noticed that when it was on my drive it was still leaking and to be honest i would rather she got it replaced and i was wondering if it's a straight forward as it looks ,i would have to do it via front ramps and it looks like just 10mm bolts remove clean and replace with the correct sealer etc...Anyone any help or advice before i start it ..Thanks
As far as I can remember it should clear the subframe and come straight down.
Clean up and replace the gasket and seal and do not overtighten bolts...should do the trick
