2004 Xtrail handbrake
Hi all. New to the forum and new to nissan. Recently bought a 2004 nissan xtrail. 2.2 dci to tow the caravan. Chuffed with the car so far except one issue. When I bought the car the lady told me the handbrake shoes had been replaced just before the lock down but as she was vulnerable smthe car had barely been used since. The handbrake seemed fine whilst on her flat level driveway however, I've found that when I stop the car and apply the handbrake. 2/3 clicks and it feels nice and tight but as soon as there is any movement in the car ie rolling slightly, there is a small clunk at the back and the handbrake realeases completely. The handbrake lever becomes extremely loose being able to pull it all the way up with no effect whatsoever. If I then drive a few metres, the handbrake goes tight again and feels great but again, slightest movement and its gone.
I've take the rear wheels and disc off and found the shoes inside the rear discs, something I've not come across before, and I can't for the life of me figure out what's wrong, the discs aren't perfect but far from being a problem and the shoes look good. Can anyone give any suggestions?  I'm due to tow the caravan tomorrow and I'm somewhat on edge about not having a handbrake.
Thanks in advance, all help and knowledge appreciated.
Jamie
Hi Jamie.....welcome to the Forum
If the shoes and mechanism looks fine then you can adjust them to the drum (inside of the disc) via a small hole on the outer face of the disc.
The hole lines up with the ratchet wheel around the 5 o'clock and 7 o'clock position on one side and the other one.
Use a flat-blade screwdriver to turn the wheel until the disc locks up, back off slightly and its adjusted.
Take up any slack on the handbrake cable and 'voila!'
Thanks Trevor, I've adjusted them twice already and as soon the handbrake is pulled up the adjuster seems to slip. I'm thinking now the thread on the adjuster is shot so im going to replace the whole mechanism.
Both sides Trevor, no friction whatsoever on either. I've just finished dismantlling the handbrake mechanism, cleaned everything up with brake cleaner, gave the shoes a little ruff up with sand paper. Re assembled the mechanism ensuring it was done correctly. I put the discs back on then got someone to pull the handbrake and the only thing I did notice is that when pulled, the shoes push outward as normal and then quite literally pop out against the front wall of the drum. I waited for this to happen then carefully removed the disc in order to see what was happening thinking perhaps one of the pins had snapped etc but no Nothing at all the shoes jumped straight back into place as if they had never moved. The 2 pins holding the shoes in place are perfectly fine and in the correct position but don't seem to be holding them very well. Also the adjuster was perfectly fine. No thread damage etc no signs of slipping. I'm not entirely sure how to proceed as if this is some kind design fault is a new mechanism going to be any different...
I rebuilt the handbrake mechanism on my X-Trail recently and am not convinced that they are 100% perfect even now, waited for them to bed in and re-adjusted but still leave in gear as not the most effective handbrake I've encountered.
My only thoughts are if you adjust the handbrake until the are just about slightly dragging the disc surface and then there is no sideways movement possible.
The adjustment can be made externally through the hole in the disc face.
Beyond that, I'm really not sure what else could be causing this issue.
