carl Posted September 19, 2020 Posted September 19, 2020 I have a intermittent fault on my xtrail...It keeps stalling at low speed and losing power as I'm driving along...Its not everything but enough to be annoying..........any ideas
Trevor Posted October 2, 2020 Posted October 2, 2020 Hi Carl....welcome to the Forum Sounds like the throttle pedal sensor is faulty, quite a common fault You can usually dial it in with a multimeter between certain voltages by turning the sensor to suit the required range
