Jameel_79 Posted October 18, 2020 Posted October 18, 2020 Hi Forum Members Recently purchased a 7seater Nissan X-Trail 2.0 Xtron. I realised, to my surprise, that you can’t use the fob to close windows/ sunroof if forgotten when leaving the car. Meaning you have to go back in the car and start the engine to close. Admittedly I shouldn’t be forgetting! However, it does happen and I would have expected such a feature in all modern cars to be standard. I would really appreciate if someone can point me towards a specialist/garage/mechanic in London who could potentially retrofit an auto close function for me. I know it could cost a few bucks, and potentially impact my warranty. Any pointers, guidance would be really appreciated. J
joey_turbo Posted August 9, 2021 Posted August 9, 2021 Did you manage to find anything out about this? I can see there are some modules on aliexpress: https://www.aliexpress.com/item/4001148007160.html They seem to make it look like a simple plug and play adapter to go into the door wiring. But it can't be as simple as that. For a start, the module looks like its plugged into a standard part of the loom. So not sure what happens to the part that should be plugged in there. These sort of things used to be easy enough with after market alarm systems. But not sure if many people tend to put after market alarms on cars these days, as security is supposedly so good (excluding keyless entry relay thefts)
