Tina Posted November 9, 2020 Share Posted November 9, 2020 Hey All I'm new to this site but would be grateful for any advice. I have a Quashqui Tecna dci. In April I had a flat battery, it was replaced. In May same again & another battery replaced by garage, in July same problem, garage had the car for a week checked everything, said there was something draining the battery but didn't know what, replaced the battery even though it was OK!, this weekend it has gone again, push ignition button loads of flashing symbols on dash & clicking noise but won't power up, battery reading just over 10. Have tried putting key fobs on button & starting but nothing!, even jump leads won't start it, I can open car with fob & lights come on, Any suggestions would be appreciated, going to try charging the battery today. Link to comment Share on other sites More sharing options...
Trevor Posted November 9, 2020 Share Posted November 9, 2020 Hi Tina....welcome to the Forum I would entrust the car to an auto-electrician as they should be able to diagnose the fault by looking for a large current drain and isolating different circuits until the readings drop. It is time consuming more than costly to diagnose and will be easier to find with the correct knowledge and test equipment. Let us know how you get on with it Cheers, Trevor Link to comment Share on other sites More sharing options...
Tina Posted November 9, 2020 Author Share Posted November 9, 2020 Thanks Trevor It's still on charge & still showing red!, will sort tomorrow, thanks for the advice 😊 Link to comment Share on other sites More sharing options...
