stephen Posted December 17, 2020 Share Posted December 17, 2020 For some reason, the washer fluid jets have just decided to hit the lower sections of the front screen. Due to their close proximity to the edge of the bonnet, it's virtually impossible to attempt to adjust the jets with a pin. Do the jet assemblies have to be removed from the bonnet in order to adjust them, or is there a method for adjusting them in situ? Any tips would be gratefully received! Stephen. Link to comment Share on other sites More sharing options...
Trevor Posted December 17, 2020 Share Posted December 17, 2020 Hi Stephen.....welcome to the forum I would advise filling the reservoir with a decent quality screenwash and top up with warm (not boiling) water to see if this clears it. If the jets have not physically moved then it is more likely that they have partially blocked and this is why the water is spraying off target Link to comment Share on other sites More sharing options...
stephen Posted December 17, 2020 Author Share Posted December 17, 2020 Thanks for that Trevor. I'll certainly try what you suggest. If it has no effect, do you have any tips for adjusting the jets, given my description of their location? Stephen. Link to comment Share on other sites More sharing options...
Trevor Posted December 17, 2020 Share Posted December 17, 2020 They would need unblocking rather than moving direction. Try fusewire to clear the jets if the warm water does not work.....top up with quality screenwash afterwards Link to comment Share on other sites More sharing options...
stephen Posted December 18, 2020 Author Share Posted December 18, 2020 Will do and thanks again Trevor! Link to comment Share on other sites More sharing options...
