Patricia Seath Posted December 22, 2020 Posted December 22, 2020 I have a note tekna 2017 can somebody tell me if the blind side warning is switched on does the green light show permantly on instrument panel in front of you
Trevor Posted December 23, 2020 Posted December 23, 2020 Not sure but if you walk past the mirror with it switched on and see if the light illuminates on the dash to show that there is an approaching car/object
Patricia Seath Posted December 24, 2020 Author Posted December 24, 2020 Thanks I got mixed up about which light comes on when first switched on then goes out it was the light on wing mirror that does this and the one on tachometer stays on to let me know BSW is switched on should read manual properly not bits of itÂ
Trevor Posted January 4, 2021 Posted January 4, 2021 It can sometimes be a steep learning curve when it comes to modern cars but at least you found the issue and its not a serious, or expensive fault
