Alanbradley8 Posted March 16, 2021 Share Posted March 16, 2021 Hi guys i have a 2007 pathfinder and is perfect until it reaches normal temperature then stalls and wont start, no engine warning light, no fault code, just put a new denso fuel regulator solenoid on but still same, can anybody help please Quote Link to comment Share on other sites More sharing options...
Trevor Posted March 18, 2021 Share Posted March 18, 2021 Maybe worth checking the Coolant Temperature Sensor as this may have drifted out of working range and giving an incorrect signal when the engine is hot Quote Link to comment Share on other sites More sharing options...
Mickmoonie Posted August 9, 2021 Share Posted August 9, 2021 Hi, I have the same year model with a similar problem only mine restarts after stalling, by the way the idle speed seems very low, poss why it stalls so much, it also takes ages to warm up any help would be good please. Quote Link to comment Share on other sites More sharing options...
Trevor Posted August 10, 2021 Share Posted August 10, 2021 You should be able to adjust the throttle body settings by using a scanner which can resolve the issue Quote Link to comment Share on other sites More sharing options...
Mickmoonie Posted August 10, 2021 Share Posted August 10, 2021 Thanks Trevor, I’ll phone my garage Quote Link to comment Share on other sites More sharing options...
Mickmoonie Posted August 12, 2021 Share Posted August 12, 2021 Hi do you know the part number for the sensor by any chance, the cambiere one (VE375144) says it doesn’t fit my 07 model😳 1 Quote Link to comment Share on other sites More sharing options...
Mickmoonie Posted August 18, 2021 Share Posted August 18, 2021 Will be trying a new suction control valve, will let you know if it works 1 Quote Link to comment Share on other sites More sharing options...
