Hi guys i have a 2007 pathfinder and is perfect until it reaches normal temperature then stalls and wont start, no engine warning light, no fault code, just put a new denso fuel regulator solenoid on but still same, can anybody help please
Maybe worth checking the Coolant Temperature Sensor as this may have drifted out of working range and giving an incorrect signal when the engine is hot
  • 4 months later...
Hi, I have the same year model with a similar problem only mine restarts after stalling, by the way the idle speed seems very low, poss why it stalls so much, it also takes ages to warm up  any help would be good please.
You should be able to adjust the throttle body settings by using a scanner which can resolve the issue
Hi do you know the part number for the sensor by any chance, the cambiere one (VE375144) says it doesn’t fit my 07 model😳
  • Confused 1
