Hi guys thanks accepting me in ur club, my topic is just put in two rear sensors and abs light still on, put it to computer and it’s reading that left rear sensor still faulty, and ems module reading fault . Tested wires at abs left rear and the no power reading from it. Tried right hand right ands it got a reading. Any suggestions. Thanks
1 minute ago, Ruby said:
Hi guys thanks accepting me in ur club, my topic is just put in two rear sensors and abs light still on, put it to computer and it’s reading that left rear sensor still faulty, and emc module reading fault . Tested wires at abs left rear and the no power reading from it. Tried right hand right ands it got a reading. Any suggestions. Thanks
Sorry Emc module
Have a look at the reluctor (toothed) ring .....unless it has a Gen2 type wheel bearing type.
If the air gap is incorrect or toothed ring damaged/missing then no signal.
Also check the connections again to see if pins aligned or damaged
One other thing, worth checking resistance of sensors, maybe one is bad?
