Hi we have a 2016 xtrail. Passenger front window will only go down on switch not up. Won’t work off drivers side master switch either. Drivers side front window will not go up or down. If I connect a battery straight to motor I cAn make either window go up or down. I bought new passenger motor to check this wasn’t issue. Same problem as existing motor. I bought a new drivers side master switch. Fitted and neither front windows worked. Tried day later and drivers would go up and down. Switched ignition off then on and then didn’t work anymore. Passenger side won’t work off master but will go down off passenger button but not up!! Any ideas??
