Lawless1994 Posted June 3, 2021 Posted June 3, 2021 Hi All. I have a 2017 Qashqai, The A/C isn't working properly, The issue with it is that when trying to adjust the temp or fan speed neither will increase or decrees, the display will show the temp and fan Speed change but nothing happens. The only way I can adjust the heat and fan speed is by turning the car off and back on again (doesn't change with the stop/start has to be completely off doors locked from outside, the re-enter), And even then the A/C will only work for 30 seconds to A minute. Anyone else have this issue or know what might be causing it?. Thanks
Trevor Posted June 4, 2021 Posted June 4, 2021 It sounds like the air con system could do with checking out, e.g. gas pressures and then see if this makes a difference with it cutting out
