Blackbox2342 Posted June 6, 2021 Share Posted June 6, 2021 This is really a two parted question. Firstly, my Note has the Connect 2 model. I noticed recently that some DAB stations would randomly drop out (though curiously not the BBC stations). Over the weekend the Connect unit has rebooted itself twice whilst driving. This has occured when the unit dropped DAB signal. So firstly, has anyone experienced an issue like this? And is there any potential fix? Alternatively, if I need a new unit then what's best? I've been looking into and replacing the connect 2 appears not to be a straightforward task. And the cost of a new Connect 2 from Nissan is going to run into the £1000s. I am trying to look into replacements and ideally would want another GPS unit rather than an Android or Apple unit that relies on phone signal / data. Does anyone know if units are available which use GPS? And specifically whether this is even an option in a Nissan Note vehicle? I appreciate these may be obvious questions but I've never had the need to considering replacing the radio before! Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Blackbox2342 Posted June 17, 2021 Author Share Posted June 17, 2021 Bump, has anyone else had DAB issues and if so how did they get resolved (if at all) Quote Link to comment Share on other sites More sharing options...
Trevor Posted June 21, 2021 Share Posted June 21, 2021 Usually an external antenna should resolve this. Halfords stock these, and reasonably priced Quote Link to comment Share on other sites More sharing options...
