keithsymes Posted July 6, 2021 Share Posted July 6, 2021 hi had a cracked windscreen and ended up at Autoglass for a for a replacement screen. They refused to fit the screen because they said there was a fault on the lane camera which would make it risky for them to recalibrate . the camera in question is performing normal doing everything it should do.ie lane discipline, high beam auto control, speed limit display and the warning beeps associated with these. had to book it in with local Nissan dealer for investigation. then hopefully i can get screen replaced, has anybody else had similar problems if so can you give me your opinions please Quote Link to comment Share on other sites More sharing options...
Trevor Posted July 8, 2021 Share Posted July 8, 2021 Hi....welcome to the Club Not sure if there is a recall issue but definitely worth taking into a Nissan dealer to have the ADAS looked at. It may be performing as it should be may not be capable of recalibrating for some reason, hence Autoglass wouldn't touch it Let us know how you get on with it Quote Link to comment Share on other sites More sharing options...
