vixcrack Posted July 8, 2021 Share Posted July 8, 2021 Hi I has anyone ever had to replace a gearbox stabiliser mount?. I have a 15plate Nissan xtrail and when I took the car to Nissan, they advised the car may require the engine mounts to be replaced at over £300k. Took the car to my local indi garage and they reckon its the gearbox stabiliser mounts that needs to be replaced at under £70. Has anyone had to replace the gearbox stabiliser mounts if so, what sort of sounds did you hear from the car. In my case, I hear a soft thud, when I compress the clutch, accelerator and also change the gears, so could this be a gearbox stabiliser mount issue? Link to comment Share on other sites More sharing options...
Trevor Posted July 23, 2021 Share Posted July 23, 2021 Its tough to say without experiencing it first hand. It is more likely to be a stabiliser mount as in the gearbox mount as it is under a backwards and forward motion that is causing the noise. Therefore, it has to be a mount or stabiliser bar that controls that motion Link to comment Share on other sites More sharing options...
