Drive shaft replacement.
vixcrack
If there is a clunking noise on acceleration or most definitely when turning full lock in one or either direction.
Also, this could be that the transmission is in 4WD on tarmac and can destroy the rear differential
Hi yes there is a clicking and clunking sound, when accelerating and also the car used to have an annoying intermittent squeak, more on the left side of the car and this is the same drive shaft that needs to be replaced, so hoping this will resolve that as well. Did you have the same issue?
