vixcrack Posted August 4, 2021 Posted August 4, 2021 Hi has anyone ever had to replace a drive shaft?. What signs did you find when you required the drive shaft replaced please?
Trevor Posted August 6, 2021 Posted August 6, 2021 If there is a clunking noise on acceleration or most definitely when turning full lock in one or either direction. Also, this could be that the transmission is in 4WD on tarmac and can destroy the rear differential
vixcrack Posted August 6, 2021 Author Posted August 6, 2021 38 minutes ago, Trevor said: If there is a clunking noise on acceleration or most definitely when turning full lock in one or either direction. Also, this could be that the transmission is in 4WD on tarmac and can destroy the rear differential Hi yes there is a clicking and clunking sound, when accelerating and also the car used to have an annoying intermittent squeak, more on the left side of the car and this is the same drive shaft that needs to be replaced, so hoping this will resolve that as well. Did you have the same issue?
Trevor Posted August 9, 2021 Posted August 9, 2021 Does sound like a driveshaft but have heard the clunking coming from the rear diff on tarmac when I've forgotten to switch it back
