Gogazeh Posted September 17, 2021 Share Posted September 17, 2021 Hi Everybody, I have remapped my NP300 2019 and DPF was removed based on the tuning company request as they said the power will be increased after removing the DPF , Currently I need to back to the stock/original software as I’m not satisfied with the power after the remapping as I have a plan to get DTE systems chip as it’s better , The Question is I need to reinstall the DPF again to come back to the car original setup , but some guys told me if I will reinstall the DPF may the car software will getting blocked and the car software will stuck then car will not start up again then I have to send it to Nissan dealer and this may will cost me more than 3000€ , So is this correct or just inaccurate expectation from him ? Did someone do the same thing before ? Thanks a lot Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 20, 2021 Share Posted September 20, 2021 Hi....welcome to the Club That does seem extreme to remove the DPF and as long as you have the parts to refit then the ECU should be able to read it once more. I would contact the tuning company to discuss reflashing the ECU with the original ECU map Quote Link to comment Share on other sites More sharing options...
